Discuss Flexi tails fitting advice in the DIY Plumbing Forum area at PlumbersForums.net
Hi guys
Im replacing a set of basin taps with a v&b mixer tap.
The flexi tails attached to the tap body have got some fitting ends that I've not seen before
The instructions have some images of what look like push fit sockets (not supplied)
I want to fit the tails to 15mm copper pipe.
Does anyone know if there is some sort of adapter that I need, or do i need to change the tails?
The brass tails on the flexis are probably 10mm, you'll need to measure or it may be stated in the instructions.
You just need 10mm x 15mm reducing coupler or elbow or whatever suits to get onto 15mm
Something like;
If they’re already 15mm the use a full bore isolation valve or coupling, if they’re 10mm then a 15mm x 10mm reducer, likewise if 12mm.
Done use push fit as it’s brass use a compression fitting
Found out last week that John Guest do a brass long tail drain off for use with speed fit fittings
Yes but there’s a special ridge to stop it flying off
Reply to Flexi tails fitting advice in the DIY Plumbing Forum area at PlumbersForums.net
Hi, As I need to purchase two new taps for our en suite, I've noticed that almost all taps now come with flexi tails as standard. I've read some...
B
Hi I have a monobloc mixer tap which is 18mths old. a leak appeared underneath in the cupboard which looked to be coming from the flexi tail M8...
Hi just purchased above tap it has 19mm flexi tails and want to fit to a standard 15mm isolation valve. Is there an adapter available as isolation...
Hi, I need some advice. I am trying to replace the manual radiator valves on a towelrail with a TRV: I ordered a Myson 2TRV15SN, and the tail...
Hi folks I need to fit a kitchen monobloc tap temporarily. A new sink unit will be going in soon so this will just be a stop gap. The current...
