Discuss I will need a help to chase a part in the Plumbing Jobs | The Job-board area at PlumbersForums.net
So then you are correct, it would need to be in a wet pocket for the bar to work? Or am I wrong?
will work with a dry but if you want pressure as well you need a wet
This is a separate device that measures flow. It is nothing to do with the gauge or fitting you showed us? How was we to know that the flow meter was fitted from your pictures?
I have never mentioned that I replaced the part Shaun has showed you?
I did mentioned from her very beginning as wel as pictures. I did tell that I will be a dry pocket for the sensus sensor
you said if i remember right a dry pocket for a temp sensor
has no effect on the heat meter just can tell the temp when you press a button
The part I received is a dry pocket isn't it ? And yes it is a for a sensor which is connected to the sensus
Just trying to help mate. Did not mean to sound shirty, but this post clearly says it measures flow. I was not questioning anything else that you had wrote. Just this paragraph.
That's alright harvest! I'm easy going.
Reply to I will need a help to chase a part in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi I have a kitchen mixer tap which allows the top part to pull out as a hose (like american sinks). It has frayed and I need t replace it, can...
I have a "Firebird Envirogreen Condensing Combi Oil Boiler 26kW" a part has went and I can't find it anywhere, I was at every plumbers merchant...
Hi guys. I've been running an UFH installation/ repair business for 7 years now and one of my main frustrations is finding the parts for the UFH...
I need to extend my central heating from my newly built extension in to the old part of my house. I need to feed 3 rads in separate bedrooms on...
Hi, I have a radiator which is unbalanced; I believe due to a missing outer part, please see the attached images. Is the missing part called a...
