- Messages
- 34,374
- Solutions
- 2
So then you are correct, it would need to be in a wet pocket for the bar to work? Or am I wrong?
will work with a dry but if you want pressure as well you need a wet
Discuss I will need a help to chase a part in the Plumbing Jobs | The Job-board area at PlumbersForums.net
This is a separate device that measures flow. It is nothing to do with the gauge or fitting you showed us? How was we to know that the flow meter was fitted from your pictures?
Yep, that's what I meant, but did not quite type the right wording. Sorrywill work with a dry but if you want pressure as well you need a wet
I have never mentioned that I replaced the part Shaun has showed you?This is a separate device that measures flow. It is nothing to do with the gauge or fitting you showed us? How was we to know that the flow meter was fitted from your pictures?
I did mentioned from her very beginning as wel as pictures. I did tell that I will be a dry pocket for the sensus sensor
It's been fitted to manufacturers instructions.needs to be inline and not in a dry pocket if thats fitted
Just trying to help mate. Did not mean to sound shirty, but this post clearly says it measures flow. I was not questioning anything else that you had wrote. Just this paragraph.Here @JCplumb as @ShaunCorbs has explained.
It basically reads the temperature and how much water the tenants use
The part I received is a dry pocket isn't it ? And yes it is a for a sensor which is connected to the sensusyou said if i remember right a dry pocket for a temp sensor
has no effect on the heat meter just can tell the temp when you press a button
Reply to I will need a help to chase a part in the Plumbing Jobs | The Job-board area at PlumbersForums.net
