Discuss trv on 10mm in the Plumbing Jobs | The Job-board area at PlumbersForums.net
pauls
i need to change a trv that is on 10mm, the trv is a 15mm with the insert olive jobby you get. if i change the trv and leave it on the old insert olive will it re-seal like a normal olive.
its one of them jobs where you just cant make adjustments without making more work etc, the 10mm comes out the wall straight on an elbow and soldering on a new pice is a bit close to the elbow. icould sweat it off but my luck it will spring back into the plasterboard and that would just make the day lol.
if its a one part reducer you may have problems with leaks if its a 3 part reducing set it should be ok just use some ptfe or jetblue on it when it goes back together
whats the difference with 1 part and three part never noticed, i dont use them really i preffer to use an extended 15x10mm reducer cut down so it sits just nice in the nut.
Reply to trv on 10mm in the Plumbing Jobs | The Job-board area at PlumbersForums.net
C
Hi there, i’m in the process of remodelling a new build home and have a towel radiator i will be fitting soon to replace an ugly traditional...
1K
M
Hope this is in the right forum. We've a utility room radiator with 10mm pipework; fitted about 6 years ago it has a BOSS TRV which has failed...
3K
Hi, Short version: I have about 4" of pipe sticking out of a concrete floor in a cupboard. It makes a 45-degree bend as it exists (bent, not with...
1K
Good evening - I wonder if anyone can shed some light on this. Squealing high pitch TRV's when reaching the required shut-off temp. I understand...
1K
My kitchen radiator is filling with hot water despite my TRV being set to 0. It's blazing at maximum. This goes for the rad when I try two...
2K
