Hello! Please avice guys, how ofter pipe clips dhould be when running copper pipe horizontaly. Thank you
How far fist clip should be from soldered fitting? Can clips be placed every 300mm along run? Or its abit of overkill?
Thanks Shaun, but what is the normal regs all plumbers follow? 150mm from fitting then next clip at 1200mm?
Yep or what looks right depending on space / the wallAs i have placed first and second clip at 120mm without any clips next to soldered fitting. So solution will be to add first clip 200mm after the fitting?
I t will be like that: 200mm first clip after fitting, second clip 1000mm from fist clip, third clip 1200mm from second clip.
