How far fist clip should be from soldered fitting? Can clips be placed every 300mm along run? Or its abit of overkill?
I would go 6”/150mm you can go closer if you wrap it with a wet cloth etc
And excess clips could cause expansion noise depending on how tight they are
Thanks Shaun, but what is the normal regs all plumbers follow? 150mm from fitting then next clip at 1200mm? As i have placed first and second clip at 120mm without any clips next to soldered fitting.
As i have placed first and second clip at 120mm without any clips next to soldered fitting. So solution will be to add first clip 200mm after the fitting?
I t will be like that: 200mm first clip after fitting, second clip 1000mm from fist clip, third clip 1200mm from second clip.
Yep or what looks right depending on space / the wall
