Well £1500 spent, and ONLY 2 hours fitting Baxi 28HE is in !!
The flu took about 25 mins !!
Think i am in the wrong trade !!
No powerflush I assume
This was what was stated, i was not there at time of fitting.
Baxi duo tec 28
New flue supported as well through roof
Chemical flush
Hot flush
Inhibitor
All required documentation Registration with gas safe Warranty
£1500
You also cannot get all documents on the day. The boiler has to be registered with manufacturer and gas safe. Paperwork takes a few days normally. Also definitely no powerflush there. Any filters?
  • Agree
Reactions: Riley
We aren’t trying to cause issue but just concerned for your cash
I do have pic BUT it's just the boiler itself, i was surprised ALL the existing Ferroli piping virtually aligned with the Baxi, ie no crossovers.
I did go up the attic as well and checked the flue etc, all new x2 45 degrees and x2 supports. (I installed a wired room stat i had spare).
ALL other quotes were £1550-£1700.
Cannot see a filter on the heating or on the incoming. I also wouldn’t couple the condense like that. But as long as it is safe and you are happy.
Also you shouldn’t be taking the case off the boiler to fit your stat. YOU ARE NOT GAS SAFE REGISTERED.
I had a gas safe cert, boiler was registered on the day with baxi andgas safe register, i will have them in the post, no filter.
I never removed the boiler cover just 'dropped down' the the bottom part to remove link/fit stat...
I'm a spark, how many plumbers on here are Part P or similar to connect the mains ??
Don't need to be part p unless your fitting the fused spur from that were fine to wire
Reactions: bilabonic
No filter mean no warranty. They need to fit a filter.
In theory if cleaned and inhb installed there's no need for a filter but it's worth a 100 just for peace of mind
Warrenty ok with no filter aslong as system is cleaned / clean
The first thing they do now from what I am told is a water check? Not sure it will be clean enough in 2 hours?
