ADVISE PLEASE - What replacement boiler for Ferroli DOMIcompact F24B ?
View the thread, titled "ADVISE PLEASE - What replacement boiler for Ferroli DOMIcompact F24B ?" which is posted in Boiler Advice Forum on UK Plumbers Forums.
You also cannot get all documents on the day. The boiler has to be registered with manufacturer and gas safe. Paperwork takes a few days normally. Also definitely no powerflush there. Any filters?
I had a gas safe cert, boiler was registered on the day with baxi andgas safe register, i will have them in the post, no filter.
I never removed the boiler cover just 'dropped down' the the bottom part to remove link/fit stat...
I'm a spark, how many plumbers on here are Part P or similar to connect the mains ??
Don't need to be part p unless your fitting the fused spur from that were fine to wire
In theory if cleaned and inhb installed there's no need for a filter but it's worth a 100 just for peace of mind
Warrenty ok with no filter aslong as system is cleaned / clean
The first thing they do now from what I am told is a water check? Not sure it will be clean enough in 2 hours?
I just checked also and yep. You are correct about filter. Sorry. However it does state that it has to be flushed properly and I doubt your system would have been clean in 2 hours.
No filter mean no warranty. They need to fit a filter.
You mean inline scale filter or magnetic filter? Having no magnetic filter doesn't void warranty even tho its good practice to fit one...system needs to be crystal clean mind. Don't have to fit scale filters down this way so not sure.
I have seen companies honour warranties with dirty water because a magnetic filter has been fitted.
Inline is a must up here.
Reply to the thread, titled "ADVISE PLEASE - What replacement boiler for Ferroli DOMIcompact F24B ?" which is posted in Boiler Advice Forum on Plumbers Forums.
bilabonic,
Harvest Fields,
