Back boiler and fire Q
View the thread, titled "Back boiler and fire Q" which is posted in Boiler Advice Forum on UK Plumbers Forums.
Scott_D
Subscribed
Quoting to convert from a back boiler to combi.
The customer has been told by another that they can keep the fire connected to the gas and I always thought that couldn’t be done.
what do you guys think?
Would think that if you leave the old boiler in place it would keep the flue as per M.I. as you can use a fire without the boiler running. Would ring the manufacturer for advise though
If you drain and permanently disconnect the back boiler from gas, electric and heating but leave it in place, there is no problem.
You may also look at closing up the ventilation.
The flue from the fire will obviously still utilize the boiler hood but it is designed to do that.
Yes done it a number of times. Disconnect the gas to the back boiler unit and cap leaving fire connected. Drain boiler and seal up, disconnect electrics.
Reply to the thread, titled "Back boiler and fire Q" which is posted in Boiler Advice Forum on Plumbers Forums.
Scott_D,
EvilDrPorkChop,
