SafeGasInstall
Subscribed
Oct 30, 2010
8,573
2,333
113
Feedback of my 1 BAXI heat only boiler !
over all
easy to install
vertical flue was easy done
boiler works really quiet
there is inspection glass to see flame
CO/CO2 really good 0.0005
the only thing I did not like is the way the boiler case fits the boiler
will fit them again
Did you find the condensate connection a bit crap? They used to be a nightmare, the rubber washer used to be a bit to sloppy when it was around the pipe.
They might have changed it then, probably had to change it cause of a rubbish washer.
posible as i did not see anything wrong with it , only the prv was a bit hard to connect 🙂 lol
How did the Powerflush go? Never been blown away by them to be honest.
Got about 2kg of oxides out ! If I had my labour I would have wash them manually first but as I was quiet for long time could not afford to have some one with me on this job !
You use that big Magnaclean double filter thing (the name escapes me)? I've left that on for a week and had the same out as a day spent power flushing.
We got these
imagejpeg
imagejpeg
