H
Hybrid
I flux the tube but if there's a little bit of water i'll flux the fitting aswell and some times put a dab on the solder. Never fails.
Save all this faff with flux, solder, mirror to check if the solder's gone all the way round, cleaning fingers, cleaning flux brush, hot blow torch, scorch marks, shreaded heat mat, etc ...
Slap on a pushfit ...
My rule is, I put as much on till I am happy the fitting is fully soldered & neatly wiped, & don't care if it means a little or a lot of solderWho follows the rule:
Use the same length of solder as the diameter of the fitting, i.e two lots of 22mm of solder for each side of a 22mm coupling.
i just flux the pipe and put fitting on with a twist to make sure of an even coverage, and i use la-co
Spend the morning soldering with Laco and then have a ***, it tastes of flux, yuk!
