C
Chris.merrick5
I have recently had a new combi condensing boiler installed in my flat which is working great but the flue does drip a little bit onto the patio of the lady in the flat below.
I have had the installer back twice to first adjust the angle an then fit a kit which looks like a submarine periscope!
It is still dripping from the very end slightly and the lady downstairs is complaining. What can I do? The installer said that with modern boilers this happens as the outside temperature is so much colder than the steam from the flue a bit of condensation dripping is unavoidable!
I'm quite concerned as the lady downstairs believes it to be acidic and a hazard! What can I do? Surely the cold air in contact with the hot flue can't be avoided?
Any comments or advice would be really appreciated!
Many thanks
Chris
That was what I thought but the new flue pluming kit the guy put on has three bends in it and the top where the drip is coming from is about a foot higher than where the flue comes through the wall so surely it can't e a case of condense running the wrong way?
Imagine a smaller version of this
[DLMURL]http://www.burgeandgunson.co.uk/heating/Vaillant_images/VTK_ecoLEVEL.gif[/DLMURL]
not a lot can be done with this as i have said before dripping of flues is unavoidable the trouble is all condensers are fan flued the fan is chucking the water out,so a plume kit wont help,the problem is the acidic condensate will mark the patio
I've read that if you apply some sort of grease to the flue then it will stop the condensation accumulating? Is this the case and can anyone recommend a particular product for this? Would a generic silicone grease from B&Q do the trick?
Ive got this problem on a big combi Ive just fitted, the problem now is if the wind is blowing it blows the acidic condense onto the surface mounted copper gas pipe, Iam just going to have to fit a plume kit to direct it away from the pipe,.
Doesn't help but out of interest. Would a non condensing bolier have been permitted in this instance. ie over a patio area?
No. For it to have been acceptable to fit a non condensing boiler the installation site of the boiler has to fit certain criteria ie if theres no where to run a condense drain etc etc (there is a check list).
I though one of the criteria was what was beneath the flue outlet. In this case someone elses patio.
All flue installers should install a drip tray ,like a gutter type shape, just under the flue and attached to wall with a drain pipe linking with waste pipe. Done
That made me laugh out loud! Any fule kno that the correct way to catch drips is to terminate the flue internally, above a bath, basin or sink....
<disclaimer - the above comment does not constitute actual advice and may be hazardous to health>
Reactions: 6 people
