R
Renewable M
didnt answer earlier as when i see oil and solid fuel mentioned im sure theres better qualified than me
going up and over isnt a problem best if you can make the fe tank and vents on the highest point rather than troublesome aavs
do a google on an item called a neutralliser wich takes two boilers but basicly is just a header as mig mentioned
pump on each circuit into a header then one pump and controlls to cyl and heating?but not sure if that would be sufficent heat dump for solid fuel
probably been easier if it was some type of heatstore rather than a twin coil cylinder
im rambling a bit just throwing ideas around as not my area
thinking logically the solid is the uncontrolable sytem so start with how that needs to be run and then work out how to incorperate the oil
yes but you cannot have the neutraliser as the highest point in the gravity circuit. heat rises. it doesnt then 'fall' and you CANNOT PUMP IT BECAUSE IT CONTRAVENES BUILDING REGS.
