Gas hob installation please help
View the thread, titled "Gas hob installation please help" which is posted in Gas Engineers Forum on UK Plumbers Forums.
Steve, they normally they come with 2 fibre washers, 1 for each side of the ally elbow
Taper thread on to parallel thread with paste or unsintered PTFE ok. Parallel thread on to parallel thread is a definite no no unless you have a washer.
one thing to remember is that even tho the manufacturer may state its ok to use a flexible hose the hose must not be exposed to high temps and hang free and with no strain. So if there is a oven fitted underneath you must be certain that the hose does not touch a hot part of the oven or get to hot in the void space, or get put under strain. As most ovens use this space as a vent/cooling route i would say that your better going with copper to be sure.
Lovely stuff image.jpg🙂
Reply to the thread, titled "Gas hob installation please help" which is posted in Gas Engineers Forum on Plumbers Forums.
plumbdoctor,
plumbdoctor,
