View the thread, titled "Gas in flats" which is posted in Gas Engineers Forum on UK Plumbers Forums.
ShaunCorbs
Super Moderator
Staff member
S. Mod
Subscribed
Got a set of flats that I need to sort out gas for (lpg) now what are the regs / am I able to run gas piping through the floor / ceiling that isn’t going to that property eg flat
I think yes but needs to be sleeved and fire clips just doubting myself / questioning
I dont think you can run a gas supply through another property
Any future access for inspection/repair would be impossible
How do they get around it in big developments as normally see a load of trac pipe running all over the place ? Might be a phone call to gas safe
Would make my life easier as else it’s running about 40m extra around the building
Yes you can.
But I believe it has to be ducted and only vertical.
The other week I was preparing to cut out an old gas service from a ground floor flat, as it was in the way in the larder. Had dust sheets down, the recip saw and extension set up, and the occupants told to leave the room 'cos of the sparks. Fortunately, I double checked, and found the old riser had a live yellow MDPE running through it. Only knew because I removed an elbow and old, disused GF gas ECV , thus giving me sight of the yellow.
I obviously left it but added gas ID tape
Yes you can.
Need horizontal
Run from outside into the floor space of the above flat, then into the next flat along (the last flat )
Two flats downstairs
One up
Think about gas pipes in voids and ventilation of said void. You also need an ecv at the point the gas enters the flat. I don’t think you can run in someone else’s property. The blocks of flats I worked on years ago always went for external runs as it was cheaper than a riser. Remember all that fuss years ago about running in new build floors? I think the principle is the same, if gas could theoretically build up in a void then the void must be ventilated to prevent potential explosive build up.
But it would be vented via the whole sleeve
Ecv would be at meters one end and an aecv when it enters
Will ring gas safe tomorrow
Will be interesting to hear what GS day.
My money is on that it can go through another flat but only vertically and be ducted.
Any more bets?
Vertical gas riser as described in the regs / corgi book... however the fact I said corgi tells you its 10 years at least since I was involved in gas in flats! I too am curious to hear gas safes take on it
Got a response
Fine going vertical or horizontal across just needs to be sleeved and no joints in other property/ flat
If going through a fire wall needs to be fire stopped etc
So just normal things
Got a response
Sleeved the entire length?
Eg through waste pipe?
Reply to the thread, titled "Gas in flats" which is posted in Gas Engineers Forum on Plumbers Forums.
Thread starter
ShaunCorbs
Staff member
S. Mod
Subscribed
Super Moderator
Joined
Location
North Wales (so hide all your sheep) :D
Heating Engineer (Has GSR)
Thread Information
Title
Gas in flats
Prefix
N/A
Forum
Gas Engineers Forum
Start date
Last reply date
Thread Tags
Tags Tags
gas engineer
ShaunCorbs,
ShaunCorbs,
