Sorry I hadn't realised in was important.
Grant Vortex Utility 15-26 set to 23. Install in 2005.
There are only 10 rads in the house, so I doubt if they add up to 23kW; probably not much more than 15-20kW. As oil boilers do not modulate, the boiler will be cycling wth a 65/35 on/off period.With rads only on and assuming they are emitting/absorbing that 23 kw then a flow rate of ~ 18/20 LPM should give a rad(s) delta T of ~ 17C so either PP2 or CP1 might do the job.
You are correct, the Rads are about 16kW and the HW is 14.5kW. So I do get a bit of cycling. The excess covers the overlap when both are calling for heat. I have run the boiler at 19kW, but when the smaler burner burnt out, it was replaced with the std one which then give 23kW. Maybe I should consider the saller burner at the next service.There are only 10 rads in the house, so I doubt if they add up to 23kW; probably not much more than 15-20kW. As oil boilers do not modulate, the boiler will be cycling wth a 65/35 on/off period.
I have also re-checked the numbers, and CP1 = 20W; CP2= 35W. Some of the thermostatic valves are now shut as the weather is warm (Devon is 25C)
Where do you get your numbers from:Something else that caught my eye there in the numbers, see attachment, if you look at the head/flowrates for CP2 and CP1, CP2 is showing a flow rate of 0.95 m3/[email protected] and CP1, 1.1 M3/hr@3M, maybe I'm reading the curves incorrectly but for the same system resistance these two readings are incompattible?, a flow of 1.1 M3/h@ 3m = 1.35 M3/[email protected] or 0.95 M3/[email protected] = 0.78 M3/hr@3M.
I got bored and switched off!Wow this is a proper pump love in isn’t it
I thought that's what you had done; just wanted to be sure.The (very) top table (composite file) are my results from the below:
etc etc
Don't forget that when the pump is in a constant pressure mode it will vary the output to maintain the required pressure. The fact that the pressure may be too high or too low is irrelevant.
