HALL of SHAME PHOTo`s
Complaints of squeaking pipes, the pipes were so tight through the joist that I had to drill them out. External making good left a lot to be desired.
Last one now. The cable on the left had been chewed by rats and blown the hole in the pipe on the right.
I need to get me camera sorted.
The stuff I see over here, still freaks me out & I was last G.O.R.G.I registered over 12 years ago!!!
Id like to come out with you mike for a week some of the stuff you find
I've got a reputation for sorting out other peoples messes so I used to get sent out to this sort of stuff a lot. I got pulled off installs and put on remedials at the end of July and carried on with them until my redundancy on the 16th December. I'm hoping to see less of it now I'm back on my own but today's gas farce doesn't bode well for the future.
This is not so much a dodgy install but a case of dodgy engineers failing to spot a problem. 13 engiineers had been to the job prior to my visit and caused all sorts of problems trying to find the cause of the overflow on the header tank. Either no one else had noticed the drip coming from the open vent with the system off or hadn't realised its significance. The cold water storage cistern was at a higher level than the header tank and it was obviously a split coil causing the problem. The pump had been moved, the primaries upgraded, a bypass put in complete with various leaks through the ceiling in attempts to solve the problem.This had been going on for 15 months and we had to repaint the side of the custards house due to the brown staining from the continuous overflowing.
Joining in 🙂 How's this for a flue position? 2011-02-24 14.26.06.jpg2011-02-24 14.25.57.jpg
Haha that gate valve is a great one! I'm putting my camera in the van from now on. (no my phone really is that rubbish!)
Judging by the boarded up door below, I think they could be squatters.....which would explain the terribleness of it.
It was an in progress extension on the back of some flats ... !!! I think they used every possible variety of plastic available .... :lol:
That gas meter must have been a joke?!
As for the cooker, looks like someone set it on fire and it's been doused in water to put it out - they were obviously too lazy to then clean it up!
GAs meter was straight off the mains supplying a communial church hall 🙂 ... Now been flattened, I passed there a cupl months back 🙂
I had to ring Heat Team about this as I had never come across something like this before. They confirmed that you can have a maximum of 5 meters drop on the flue, taking off a meter per elbow. So this is actually ok. But my god does it look dodgy!
This might be ok, I didn't actually go to this property I just noticed it on my travels and took a pic.
Barry98,
Harvest Fields,
