A
View attachment 16939 Spot the problem or problems
View attachment 16937 Can you fit my hob he said .... It's a easy strait swap he said .....
With all the room available why put it over the lid that I need to remove? Not to mention using an olive compression fitting on white waste overflow pipe.
He used brass 22mm compression fitting on 21.5mm plastic which goes up in to loft and is full of water, then added the drain off right next door to the fused spur.That's ruff as...
Is it a 22mm fitting loosely fitted onto 21.5mm pipe?.
Al
Not sure if they were trying to save some money on copper or what
thats screaming out for a fan to be bolted to the wall above it, diy blower. oh yeah.
