What on the soil ? Or are the houses really posh? I would say empty all your pockets and get a bucket cut down to move tools around?
A good way to crawl below floorboards is get some good thick cardboard - like what comes with shower doors & boilers. Lay it down on the subfloors (which tend to be covered in rubble often) & you can just slide yourself on it very easily & it can be very comfortable & warm also.
Don't let a blow lamp near it though!
No on the oversite
U must strike it lucky. Normally old houses with decent voids have no over site or loads of rubbish under there or new ones har a 200mm void. No trolley will help me in an 200mm void as my middle engine is a little bigger than that!
Keep an old cast wheel head from a gate valve (not the pressed tin ones) in the toolbox. They fit most lock shields aswell as gate valves. Makes rad-work easy 🙂
Reactions: 4 people
Old radiator brackets can be used to strengthen boxing or cupboards if you've pulled them apart, ugly but effective. Also they can be used to support floorboards of you've cut them a touch too short
Reactions: 4 people
Sentinel bottles make great drip trays. And look better than Ones with aldi chicken thighs written on them
If you don't know what your doing leave it alone, or if the urge is too strong, at least talk to somebody who does 1st.
Pair of Moles to help set up your soldering
(Please excuse the coupling, just got that length wrong and didn't have another length within reach 🙂 )
