one just popped to me today (im sure others will have used it plenty like as its so obvious but hey) when replacing a towel rad or standered rad upstairs and you cant find a drain off without lifting a trap or 2, find a downstairs rad has modern bleed valves you can drain straight into a large flexy tub through the bleed valve nice and easy allthough this wont allways work if all rads have been dropped from above
Far better to isolate valves and remove vent plug and replace with a compression coupler with a bit of pipe on it then open valves and fill a bucket or stick hose on pipe.
Isn't that pretty much what the OP is saying?
also would be handy when you have a "nice" blocked toilet or drainsKeep some Vicks vapour rub in van. When your in a nice fragrant dwelling a small amount of Vicks under you nose will help u feel less dirty.
dont put pushfit on chrome pipe.......ever
Souds like a description from the Viz profanasourus!
when our pipe slices get less effective at cutting copper put some flux over night it stiffens them up and they will work better
