if you get a tap that has loosened up because of a split top hat and you cant undo the water connection or cant get to it easily (i have had this happen before) . instead of undoing the water connection , jest unscrew the backnut a bit down the tap thread . then cut a 1 1/2" (ish) square piece of ply and drill a central 20mm hole in it, then cut from side to the hole as to create a kind of C piece of ply that can be slid easily inbetween the bottom of the sink and he backnut , then tighten in back again , this acts as a tophat without the need to dissconnect the tap if you cant turn the water off or something!
Reactions: 3 people
if you get a snapped lockshield pin because somebody has closed it too tight with a wrench and you cant open it again because it has snapped too low to the gland , jest undo the gland nut totally then you have much more of the pin to hold with pliers to open it again , obviously you would jest replace the lockshield , but this trick has helped me out before, dont know if its just common sence but i struggled for a while trying to open it before this idea came to my head!
im a maintance plumber at the moment, i often get broken trv heads because somebody kicked them by "accident" or something, i work for somebody else so i keep a small box of various old heads in my van for a quick replacement, my pocket personally would not benifit from a draindown or whatever for a valve replacement! i get them from other guys in work that do heating replacements!
spray shower door runners with silacone spray , does a hell of a diference ! they run much smoother!!! also gives the van dashboard a lovelly smell & shine!!!!
You can get split top hats mate
Or make your own using one of these tools.
You could try a Split Klick top hat washer, does the same thing
Never start a bathroom until you have all the sanitaryware on site ,even if your merchants guarantees it will be there on set day !!
Reactions: 5 people
this doesn't really work if your a sole trader but more of an employee
if while your cleaning up and a customer tells you "don't worry about that i'll get that" and you leave assuming the customer is quite happy cleaning up the remainder of the mess no matter how small, INSIST that you finish up cleaning up and its part of the job.
This happened to me before it was 7pm and the following day I got pulled up from the boss because customer complained about the mess I left.
Trust no one!
Reactions: 5 people
If the customer wishes to do the labouring for the job and you are happy with that, you need to write down exactly what you need them to do and what they are not expected to do when you put your price together.
Never loads the rubbish into the van without first making sure they don't mind you taking the scrap.
If they want the scrap, they can also have the rubbish.
Someone got me with the a few weeks back.
to avoid that :
always list on your quote/estimate remove of rubbish and scrap mettal is included in the price
I always state "remove and clear away". The money from the scrap pays for the waste removal and my waste licence. If the customer wants to keep the scrap they can pay a disposal charge for the rubbish.
Reactions: 4 people
And also illegal. It will make a really good impression on your customers when your picture is splashed across the local paper leaving court after you've been prosecuted for the illegal disposal of trade waste. I know the cost of rubbish disposal hurts but it's something we all have to live with.
I usually just cost in the size of an appropriate sized hippo bag, clean tidy ,collected no bother. Plus I only have a teeny weeny van 🙂
if your letting the scrap men take rads from site have a bucket of water handy cos they dribble black muck everywhere everytime..
I'm currently only doing boilers so my scrappy takes my old boilers and my rubbish for £15 per boiler, Yes I know i could make more by stripping down but I'm too busy and he takes my rubbish away so I win and he wins. If you could find a similar arrangement then happy days
If you are replacing an open vented boiler which has the flow and return drop feeding from above into the boiler and there are currently no air vents cut into the pipes above, then save yourself alot of hassle and install air vents while you install the boiler otherwise you will be trying to shift an airlock for quite some time.
especially if there is very little head of pressure, and the cold mains is poor
pump wasnt next to boiler though it was quite a bit away next to cylinder, and the new boiler wasnt top entry was bottom
I understand but I would have not fitted any unless pipe work from boiler had a long horizontal run ......
I would have fitted and I alway do a drain of on the return just next to boiler and when filling up I always run hw only first and then run ch separately ....
We all had them 2-3h to clear the air lock on a open vent boilers ....🙂
keep the plastic plugs that protect the tappings in new rads and put them into the tappings of the old rads, this will stop getting black sludge everywhere, this also helps when carrying a rad down stairs or in a clean property.
Reactions: 3 people
Cracking idea !
if both inlets are at bottom, turn rad upside down, simples 🙂
Reactions: 2 people
No not simples, read post 817 plastic plugs will stop this, also will stop sludge running round your van if you are taking a rad away, also carrying a large rad downstairs and you never know you may trip when carrying a rad, as you know black sludge goes through dustsheets. your idea is fine if in a property with no carpet and you are putting a rad directly into a skip.
i always spin em upside down through properties so sludge in house not a problem..like the plug idea to stop the scrappys jackson pollocks'in the drive.
I always put in the terms and conditions that the value of the scrap metal is taken into account when I arrive at the final price (in reality it covers me for unforseen extras). Regarding the rest of the waste, it really depends on how much there is and I itemise it on estimates. Some customers decide to get rid of the rubbish themselves, others ask you.
Close vent and up side down is the easiest way !! If you have time you can do what ever you like but best trick of the trade is to up side down them and rads go in the back of the van(the only safe place for scrap is back of the van without many people seeing you ) never ever leave scrap or copper pipes outside the house where you are working
When draining down, always count and record the number of rads you open. I've just worked in a very large house with 47 rads, missed the 2 in the walk in wardrobe, came back next day and had to get on with this:
Drawing and dining rooms, ceilings knackered. One sofa to recover, one large carpet to replace. Thank God for PubLib.
Worst day of my working life, the poor custards were very good about it when they came back from holiday Saturday morning. A real pride denter, stupid, avoidable mistake. I hope someone else can learn from it!
Reactions: 5 people
I feel for ya pal. thats why i hate it when custards are away or out and i have to post keys back through..Always get paranoid on the way home..
Oh flip, your an absolute sport for putting this up. That's a real ****er mate. like you say, thank god for public liability insurance!
The person that never made a mistake doesn't exist.
Bad luck fella but you will learn from this error:thumbup:
Bunker, I feel for you mate, hope everything turns out ok. I guess most of us if not all have made a similar mistake.
to all the very new plumbers, be carefull how much solder you apply to microbore fittings. spent an hour faffing around with a luke warm rad only to find one of the young lads had partially blocked the 10mm elbow with solder doh.
Reactions: 4 people
When fitting chrome pipe to bathroom towel rads use a dremel with the stone wheel to remove the chrome takes seconds then you can solder to the exposed copper. You can sleep at night once the tiles are down?
Reactions: 4 people
ive been using "frame fixers" or whatever they are called to fix wc's to floor lately! simple job! just fut the flange off the plug! no faffing arounf with plugs not entering the holes you have drilled ect!!
Brass 3" 12's do me Chris. I certainly wouldn't use a frame fix.
Yes, sorry but the floors are not so good down here as the granite you may be use too Tamz
(PS you are right it was 3 not 4 oh how old age effects the memory that & the bottle of wine, well it has been a good day, sun shining Alpha solar kit installed & the BL-----dy kids not back until Monday, O a few more days of bliss)
if ever doing a combi to combi swap, have a wee peak up in the loft you never know some one might have left you a little present i.e hot water cylinder or some scrap pipe at least:christmaswreath:
Reactions: 3 people
Strip foam cylinder by cutting it from top to bottom so it's segmented, do this in 3 or 4 places. Once around circumference mid way up cylinder. Cut as deep as u can through foam. Lay on its side and stamp on it once or twice. Insulation comes off in about 8 bits not 20000.
Tip two buy recip saw and u will never leave any loot behind in an attic or tight space again.
when fitting rads under a window sill measure down from the sill for top of bracket height fix brackets pop rad in place check levels and whichever side is the high spot pop the bleed valve on . I go to quite a few complaints (not my jobs) that are rads that seem un level when infact its spot on but they look out because of the sills
I'd speak to customer first. "Do you want rad level or parallel to windowsill?"
With some people no matter what you do they will find a problem.
Reactions: 3 people
fair play I just do it as a standard only ever had one customer follow me round with a level and they didn't find one level rad of mine all the ones under the window sill were perfectly parallel and every other rad I fit I send a level line across fit brackets check for level and if they are spot on I send a tiny tap to one of the brackets I was always taught to have a slight un level on rads up to the bleed nipple and as I think its make perfect cense that's how I fit them ime not talking much but over sat a 1200 level 2 milly is in my eyes perfect
note to self: when reconnecting appliances in property where council have been in and decommisioned it, check EVERY connection on every appliance including supply! numbnuts had loosened the supply to the meter put new olive in and just turned nut slightly ... i got wet
install slam locks on van. very handy and very good, saves having to use keys if you are struggling with anything heavy and time wondering if you've locked it or not ... just remember to check you have keys in pocket before you slam though 🙂
When change a immersion heater , make sure you remove old gasket and clean the sitting with Stanley blade and then install the new immersion heater
If every using anybody else's electric appliances or set ups, in my case my uncles set up for the light in his loft......
Just have a quick check for obvious defects or potential problems.
I got a belt from a horrific DIY job where my uncle had wired a plug on both ends of a flex to power the light in the loft.
I didn't check this and when I unplugged one end, it was still live as other end was plugged in and it hurt!!
ч
Tell uncle never to play with electrics like this ..... Is this even allowed !?
To aid adding inhibitor, leak sealer or cleaner ect Make one of these up, keep compression fitting loose as then u can keep filler upright and tighten into rad. Take blanking plug out of other side as it avoids gurgling.
Solder a bit of 15mm into a 1/2 to 3/4 rad stump. Attach to hose. Draining down via a rad or makes syphoning easier. If rads are 15mm tail type just attach 3/4 valve and use 15mm connection.
Reactions: 4 people
I have a drain of hose exactly the same as that one great if theres no drain off hopefully snatch a small radiator and drain away
for inhibitor i use half an auto air vent and bent male iron with o ring, and the very same make up for draining with no drain off. good call.
if you come across a deck sink tap thats leaking from the spout to deck joint and theres no grub screws. turn the spout usually to the right so its parallel with the cold head and pull and wiggle it up. theres a spring loaded bearing and a slot in the deck that makes it only possible to pull out at this angle. re o ring and replace..jobs a goodun.
I will remember that one changed my mothers only yesterday for the reason that I couldn't find a grub screw! to be fair it was time for a change anyway
Get a ladder base mate
Then ur ladder will be a lot safer when ur on the 3rd floor roof. Or helping dickie of his horse. Also a ratchet strap fastened to wall will make u a lot safer !
Who's been on a ladder access course then :smile:
Don't forget your ropes and bucket hook :lol:
Need to change a syphon that wont flush.get a hose that is long enough to reach the pan and suck. Oviously not while in the pan. If its low enough the hose will syphon out the water and you can whip it off the wall without being full. 🙂
Bloo loo tastes worse than diesel. I'll stick to a sponge :wink:
Wet vac indeed. But if you dnt have one. Oh yeh tamz, like limescale on cylinder when drainoff dnt work lol.
Aye right Simon. I'll humpf a hoover up a flat stair to suck 2 pint of water out a cistern. Don't think so. I'd have the job done before you got it out the van even if it meant cracking the ballvalve jamb nut and wiping it up with a towel :wink:
Keep some spare test nipples in your bag! Nothing worse than one snapping off or worse loosing it in a semi concealed ! If u do snap off head of nipple simply get a good flathead screwdriver, put inside test point and give it a few whacks with hammer to get grip and unscrew! Obviously only should be done by a GSRI
im with you tamz anyone can do it with a small artic full 0of tools and spares what sorts the men from the boys is doing it with what you can carry olive splitters and fancy drain bowls comes to mind
or use a speedfit you have taking off a leaking DIY install :devil2: you only need to screw into the rad hand tight, no tools needed
Reactions: 2 people
If you use a full bore iso, and ran a bit of thin tube, maybe microbore through that assembly, the inhibitor would flow into the rad without even a glug - you ever shotgunned a bottle of beer witha straw in it? Works a treat!!
Reactions: 2 people
When you need to drain off only an upstairs but have a great drain point downstairs, hang your hose in a tree/ garage roof etc.
To Oil installers:
When you put a lovely new boiler in a lovely boiler room with all your lovely wiring centres and isolator switches......PLEASE please please, put a single socket in for my hoover...
Reactions: 3 people
