Hints, tips & secrets of plumbing - No Banter please!
View the thread, titled "Hints, tips & secrets of plumbing - No Banter please!" which is posted in UK Plumbers Forums on UK Plumbers Forums.
re: Hints, tips & secrets of plumbing - No Banter please!
the flarer nis good for pipes that have been frozen youll not get those in a compression coupling
I did mean to use compression when you have imperial pipe work and want to convert to metrick Steve ! However I don't know after a pipes base been fleared how do you join them ?
When adding inhibitor or cleaner to a system, shut off both sides drain a few litres or so then use a 15mm compression elbow in the top of the rad to pour inn your chemicals...
To people in the know this is probably obvious but to me it's not, how does the 15mm elbow connect to the top of the rad?
i meant to solder especially where ya cant get at it again, the only prob with comp is that 3/4 to 22mm is proper baggy and needs to be tightend to death.
it only works on compact style rads with a 15mm bleed point/ plug you can remove Look back i posted a similar one to use a bent f/i and auto airvent body
No No No!!!
Never use a 22mm olive on 3/4" pipe as you must use a 3/4" olive on 3/4" pipe.
If you simply try and bodge and screw up a 22mm one tight or there's a good chance it will leak or the joint won't be tight when fully screwed up.
If you want to flare the pipe, heat the pipe end until really hot and allow to cool down naturally so as to soften it and leave it less likely to split when flared.
No No No!!!
behave how many new plumbers keep 3/4 olives on their vans. a 22mm comp fitting will make a good seal if tightened enough and its not a bodge by any stretch of the imagination....like i said use flaring kit if you havent got end feed converters solder all the way...
It is a bodge. 22mm olives will not tighten properly onto 3/4 pipe. They are not designed for it, should there be a leak you will be held entirely responsible for using an inappropriate fitting. There are lots of things that new plumbers may not have on their vans but that is not an excuse for not doing the job properly. When you've turned up to a job, fitted a new boiler, fired it up and a fitting has blown off the other side of the house because it is a 22 fitting bodged onto 3/4 pipe you will know what a bodge it is.
I always have 3/4" olives and 1" olives in my van as do my other plumber mates. A 22mm olive is a bodge. Crimp them up and there's a good chance they will crease and not seal properly or blow off - I have come across this after other "plumbers" have been on site. Exactly the same way as you don't try and solder a 22mm fitting onto 3/4" pipe but use a 22 x 3/4 reducer.
These details and others like them make the difference between a bodger and an expert.
I always keep stock of 3/4 olives and metric to imperial end feed couplings.
i keep a few convertor olives in the olive box tied together with a bit of solder same with the couplings saves digging through to find the right ones
I cranked up a 22mm compression fitting onto an 3/4 bit of pipe the other week as it was the discharge from an unvented. So no pressure will ever be on the joint.
I would never do it on a joint that's under pressure, as its a bodge. Adapters are pence.
i have some 3/4" olives and 3/4" to 22mm solder couplings along with slips couplings in an old small swarfega pot in the van , this way i never try to use them on normal 22mm pipe an think they ar faulty 22mm couplers and chuck then in the scrap box!
When removing rads:
(Assuming you've prepared the system appropriately and have your old towels under the valves etc)..
Have a couple of male compression caps at hand (1/2 or 3/4 dependng) and, once the rad is undone from the valve, gently separate and lob the cap in between, then do your rad-side nut up. No need to drain inside the house, no leakage, just carry outside and empty there. (obviously this will make the rad heavier so this will only work if its a smallish rad, or if there are 2 of you, or if you look like Croppie and can lift one in each hand...🙂)
When soldering and a fitting is in a tight place, heat the pipe further down from the fitting and then solder
If your in a pickle with a mildly scuffed rad get a small tub of white combined T cut and polish works a treat as long as its not too deep and will last you years..( disclaimer the right thing to do would be replace rad but hey ho).
When fitting a fluidmaster dual flush drop valve into a WC with a 2 inch cistern hole and therefore using the supplied 2 inch seal, keep the foam washer that it comes fitted with - they are better than the thin rubber ones which come with normal handle operated syphons.
While on the subject had anyone tried the handle operated fluidmaster dual flush valves (not flapper type)? Wondering if they were as reliable and the classic...
Yes. Excellent. Lift up handle for half flush and depress handle for full flush.
Best tool in my box - 52mm pump valve spanner from Screwfix. Oh god it's awesome...🙂
They are good, and a life saver if you're in a tight spot. However I've since gone back to grips for pump unions. Haven't pulled the pump spanner out in months. Simply as I have the grips in the tool box I carry onto a job and the bloody great big pump spanner is in the tool tub in the van.
COMPLAINT:
I've not been around the forum for long but having been reading it including this section, I have increasingly found my work is suffering. For example, on your appalling advice, I bought a wet n dry vacuum and have used it so many times its getting embarrassing, so much stuff is alot easier and taking LESS TIME! How am I supposed to string these jobs out now? Plus, I keep reading it like now when I should be working. It's an outrage.
tell customers to put harpic blue block in cisters of leaking toilets, had loads this year and turned out to be condesation , couldent believe it was so much water, if the base of the toilet or the flush pipe or doughnut washer is leaking you will see the blue mark from the leak , very handy if it is a very small leak, or for customers in social housing that just want a new toilet because its "leaking" when its really just condensation!
If you can't find the test point plug for the boiler after you've finished doing a combustion test, it's usually stuck to the magnet on the back of your analyser.
Reply to the thread, titled "Hints, tips & secrets of plumbing - No Banter please!" which is posted in UK Plumbers Forums on Plumbers Forums.
REDSAW,
firemant,
