Truth is all fluxes & all fittings, end feed or Yorkshire will solder okay if you prepare them & are able to solder properly.
Everyone has their own preference in fluxes etc, sometimes just because of what they are used to.
My personal preference is good quality end feed fittings & leaded solder for heating pipes & obviously lead free for potable water. I use the old fashioned grease based flux - Frys Fluxite or the similar Yorkshire Traditional flux, both of which are fairly non aggressive, but I now have the Laco flux which is non toxic.
I clean the fittings & pipes to clean copper & as well as fluxing the joints, I dab flux on end of solder as I solder. I don't believe in over heating the joints, except a little above the melting stage of soldering. If the pipe/fitting discolours, it is dirty.
