There was some flux years ago called 'Bakers Blue' I put into
my eye by accidend on M4 cause i had not washed my hands
- in the end I ripped out the washer bottle of my transit on the hard shoulder
to get an eye wash it was agony Centralheatking
Some fitter known to you all also did not clean his hands and
fingers and under his nails one evening properly and
'mucking about with his bride' to be
caused a lot of trouble - downstairs
beware centralheatking
Think you should refer to croppie as croppie no wife to be, not common knowledge you to were once married
Bunch of soft tarts. Its wire wool all the way. Just make sure there's no strands left in the fitting.
I use the toolstation one every day. Irs as good as any otherAnyone tried this then? It says it does 'metal polishing' : Toolstation > Painting & Decorating > Sanding Paper > Sanding Mesh
The 3m pads are available from farnell: 05305 - 3M - HAND PAD, 155X225, AFN, 7496 | Farnell UK
or:
3M Scotch-Brite Nylon Abrasive Hand Pads
Exactly so why pay a pound a strip for rottenbugger ones when you can have a 5metre roll from toolstation for under six quidThey all probably made in same place !
Its not so much the cleaning of the copper as saving money while doing it.....toolstation abrasive strip rules [emoji636]It's sad when we all get so excited over how to clean copper pipe 🙂 🙂 🙂
Thanks everyone for your comments. Got Yorkshires working better, but still not as good as end feed. I will still be carrying solder so will probably switch back to end feeds! The problem is usually on drained down systems - could the bad joints be down to the steam from residual water? I dry the pipe in the immediate area and assumed it would be dry enough after heating? Are Yorkshires more problematic with steam?
Have any of you ever used one of these pipe prep cleaners Rothenberger Pipe Prep Deburrer 15mm | Deburring | NoLinkingToThis
