How Will I Fix Gold Bar Mixer To Wall?
View the thread, titled "How Will I Fix Gold Bar Mixer To Wall?" which is posted in UK Plumbers Forums on UK Plumbers Forums.
I need to fix this gold coloured bar mixer to a tiled block wall to replace an old mixer that had compression elbows.
Tre Mercati Roma Gold Plated Exposed Thermostatic Shower Valve | 979A
The pipes go through the wall to the hot and cold pipes in cupboard behind shower. As the new mixer has standard shower couplings, I will need to fit a bar mixer fixing kit. These kits have larger shrouds to cover the fixings – but none are available in gold – all shrouds are chrome.
Ultra Chrome Wall Mounted Fixings - A315 at Victorian Plumbing UK
The new gold mixer comes with gold shrouds, but are shallower than the ones in the fixing kits. How can I install the mixer and use the original shrouds?
The gold shrouds will fit the chrome fixing kit.
A wee bit careful measuring and you won't see any chrome.
Think about it.
Btw want to buy some gold taps cheap 🙂
Reply to the thread, titled "How Will I Fix Gold Bar Mixer To Wall?" which is posted in UK Plumbers Forums on Plumbers Forums.
plumbandplumber,
tamz,
