ID condensate pipe??
View the thread, titled "ID condensate pipe??" which is posted in UK Plumbers Forums on UK Plumbers Forums.
Been to isar ruined as down pipe was blocked, roof tried to empty via burner in boiler, 3 visits later new boiler as it was dry when visited looked at water damage on fan and it twigged! Don't use rwp! Without air gap .
When I did my first boiler install I ran a condense into a rainwater gutter. As it was me first when it got inspected the guy (Alan Mathews) said that if the gutter got blocked you'd get corrosive water running down the bricks causing a problem. As it happened I'd fitted a neutraliser anyway so he said it was fine but in any case he wouldn't write it down as any fault at all. He said it was a non gas related issue.
this situation is slightly different, but as others have said IF the trap was empty when the boiler fired up it would take a very small amount of time to fill up again anyway. I would say NCS, and yes i feel sorry for anybody who has their boiler disconnected for that...
I got to page 6 and got extremely bored, so skipped to this page. So you had Alan Matthews round, correct in what he said. You should not discharge into rainwater or land course without neutralising the condensate. Further to this, if the rainwater became blocked and or backed up due to heavy rain this would cause problems with the boiler unless there is an air break in the pipework. Tamz is spot an as usual with this thread.
Now, how many is that I've got on end of my line??? LOL!!!
I'll ID you later.
Lol you deffo live up to your name big lad
Now trying to back track saying your on a wind up
Ps since when was being able to spell or punctuation make anyone a good plumber
Simonjohn is a good plumber
You I haven't a clue
You I haven't a clue......................
You may think that dear boy, but you're wrong. But thanks for taking the time to express your views.
When the experts can't agree, it undermines all their credibility. That why you should use the "because" word In any technical comment you make. For example The condensate Pipe should ????? "BECAUSE" Section? of manufacturer instructions and Section ? of British Standards require it to be this way.
Dickie, can we help you here at all? Would you like to share with us what’s bothering you? Insecurity? You don’t sleep well? You need help? I’d say, it’s not about condensate pipe, it’s much deeper… We might be able to help you, if we can... You might have a condition - Asperger syndrome. Do you believe that you are much more intelligent than everyone else here? Or you are just stubborn and have a bit of an ego. What causes you to be this way?
This thread is getting silly now. Also not suitable for open forum so I'm banging it into the private forum.
Everybody please get back on subject or I'll close it.
Thought subject was clearly closed by reg man? Only time it would be any different is if boiler didn't have a 75mm water trap?
Sir Alan Sugar wouldn’t be impressed!
At last, his gone. Don't mind a laugh and a joke, but this should mainly be done down the Pub, not tolerated on the technical forums. Yes can be humorous on the technical side, but not inflammatory and objectionable.
It is not classed as anything.
If you read BS6798 it is allowed. Here is a bit from it if you don't have it.
4.3.4.2 Connection to an internal waste pipe (Figure 2)
Provided that the condensate drainage pipe meets the requirements of 4.3.3 and 4.3.4, there is no length restriction.
The connection shall be made to the internal waste pipe from a sink, washing machine or dishwasher. The connection may be made either downstream [Figure 2a)] or upstream [Figure 2b)] of the waste trap.
NOTE If practical, the connection should be made to the upper part of the pipe wall.
— If the connection is downstream of the waste trap and the boiler does not have an integral condensate trap with a seal of at least 75 mm then an additional trap of at least 75 mm shall be fitted. A visible air
break shall be included between these traps.
— If the connection is upstream of the waste trap, then a visible air break is necessary between the waste trap and the condensate trap but, in the case of a sink, this is provided by the sink waste pipe itself as
long as the sink has an integral overflow.
In order to prevent waste from the sink, washing machine or dishwasher entering the condensate trap, there shall be a minimum of 100 mm between the visible air break at the lowest condensate trap and the
top of the sink or visible air break serving the washing machine or dishwasher.
All the answers are in the books if you read them.
picture 2 shows connection to the sink trap this is an open end to the room - same as putting into a w/mc trap.
Reply to the thread, titled "ID condensate pipe??" which is posted in UK Plumbers Forums on Plumbers Forums.
Dickie,
Gray0689,
