Best
Subscribed
Oct 12, 2011
10,029
5,182
113
N.Ireland, United Kingdom
General Plumber
I have been out tonight to an oil heating system that has stopped working. Boiler is in garage, but a builders plumber has fitted the red expansion & filling loop and a Joule unvented cylinder, all up in the attic and brand new.
Went to have a look and can't believe it! All plastic & push fit.
NO tundish and NO combination valve!
D1 pipe from T&P valve is 15mm plastic about 2 metres long, then a 22x15x15 push fit tee to accommodate the discharge from heating relief valve and straight into a length of 40mm waste horizontally going to outside as if an ordinary overflow!
Customer assumes plumber just took the missing parts with them. No paperwork done, although the installation & service manual was sitting on top of the unit, with the last page missing.
I have been asked to sort it all!
Are you sure the red vessel is for hot water?? You mentioned a filling loop, so would be heating.
The installation sounds a right bodge tho!
can you put cylinder in garage ? and sounds like a nice job, least the strip out will be easy
I actually suggested the unvented unit could have been put beside the oil boiler in garage.
But probably too late to do that now, - bungalow has had major work done and modernised, tiled floors etc. Most I will ever want to do is fit a complete discharge pipework including supplying a tundish and a proper combination valve all to regs.
Frankly I don't really want to work on a plastic piped unvented unit that has been done by builders idiots - it has just been sat on the flooring in the attic with no strengthening supports. (Luckily there's a wall below that area).
Oddly the customer doesn't want to confront the builder about this
The red vessel is definitely for the heating. The Joule white expansion vessel with its long flexi hose is fitted beside it, - both screwed onto the Purlin (main wooden roof beam)
It is a complete bodge, as you say! Who would fail to install a combination valve and tundish, only an idiot? I notice the Joule instructions aren't great though tbh.
The red vessel is definitely for the heating. The Joule white expansion vessel with its long flexi hose is fitted beside it, - both screwed onto the Purlong (main wooded roof beam)
Combination valve could have been fitted on the water main. Downstairs.
take a peek under the kitchen sink or where the cold main enters the house for the combination valve, been caught out before where a clever clogs hides it there to save on the copper to run the balanced cold main.
Yes, as Chalked and you suggest, I was thinking same, but couldn't be bothered checking tonight.
That still means the pressure relief valve is wrong place and to add to it - there is a 22mm gate valve fitted on feed to unit which, if turned off would isolate the relief valve from the unit.
I have already pointed this all out to customer including gate valve and possibility the missing combination valve is somewhere else.
Enjoy
Note the D1 length of plastic push fit and into a push fit tee and shoved into a 40 mm grey waste pipe between joists. This probably just terminates at roof level outside!
I've got a thick labrador who could do a better job than that.
Clearly no building control notification, no g3 qualification and no f-ing clue.
I agree. The instructions are poor, but do show the typical layout drawing of discharge pipe to tundish to a gulley and the D2 sizing formula.
Whats the point of paying 250quid to do G3 if people can get away with work like that
Mind you, they probably have their G3
Maybe he was just having a bad day?
