Lpg analyser readings?
View the thread, titled "Lpg analyser readings?" which is posted in UK Plumbers Forums on UK Plumbers Forums.
spikewt
Out of curiosity, what the norm for lpg analyser reading on a new boiler. Commissioned my first lpg new install on a heat line combi (not my choice) and once I converted it and took the readings, everything seems high but the co2% is spot on.
381ppm, 0.0037ratio
Now I thort maybe there's a problem but I fitted 2 next to each other and the readings are identical. Is this a normal reading?
MI's state no higher than 0.004 and co2% 10.3 +- 0.3 so it is in but only just and im not used to seeing high ppm's.
Just got my lpg ticket if you didn't realise.
Thanks in advance.
I know it's a stupid answer, but has happened many times.
Have you got your analyser set on lpg??
You won't be the first to leave it on natural gas, then get weird results.
Reply to the thread, titled "Lpg analyser readings?" which is posted in UK Plumbers Forums on Plumbers Forums.
spikewt,
spikewt,
