AND taped up so any potential lime cannot pin hole the copperAs per Snowhead's idea above , a brace between joists and clip to that, anything buried soldered copper only.
From the original pic and the four white pipes which ones do you think are tightly bending? Just look a wee bit curved?And you can see they’re under. Strain Speed fit is designed for quick installation it’s not designed to be pulled on tight bends
Let’s hope it is tapedAND taped up so any potential lime cannot pin hole the copper
It's not yet but will be!Let’s hope it is taped
Basically the bathroom and kitchen was first installed by different fitters and was a total bodge job. This guy has been sent to rectify and reinstall everything. The new Speedfit plastic pipe work wasn't done by this guy, he chased the radiator pipes into the wall and joined them to the existing pipes laid by the first fitters. Originally the cold water feed came straight in on plastic pipe in an arc, kinda 40 degrees or so and dropped under the floorboards, and just plastered over!Just to point out here that I assumed the whole installation was by your plumber. If I was wrong I apologise.
If you require them to reconfigure existing pipework then you will, rightly, incur additional cost. That said, it should not be unreasonable and you will have a better safer installation as a consequence.
All a bit frosty at the moment but not a total breakdown. We're all a bit stressed for obvious reasons. Them because they're picking up someone else's Rubbish and me because I have to make sure it's all done right this time. Thanks for all the replies and advice.If he’s there to rectify then he will understand where you are coming from. Jut lots of “I know it’s not your fault but...” and tea goes a long way.
My thinking too, hence why I didn't go back and tell him to change the radiator flow and return pipes which curve. I reckon they'll be ok as the water pressure won't be as much as the hot/cold feeds to the shower. May come back and haunt me I know!It might be worth a chat to explain what you expect and what they are doing. If they are a new company correcting someone else’s mess they should be cut a bit of slack to be fair.
