Poetically put Dave, truth is the workmanship is poor and can be improved on massively under no circumstances bury speedfit fittings in a wall the plastic supplies can be tidied up with little effort and if that's his best of effort of concealing pipes into a wall then your in trouble. Kop
Just for my own future knowledge (homeowner not plumber!), whats the difference between burying a fitting in the wall and under the floorboards, tile etc? If something leaks it means destruction to get to them either way, right?
Under the floor is much simpler to access. Often one can get to them from below if in the middle of the house or above if up top.
  • Agree
I would take it up with the builder who nearly demolished your bathroom wall. One thing chasing out a little plaster, but when the bathroom wall looks like a HS2 job...Sod take!
Quality job takes time ! time it’s money !
So either it’s cheaper and half decent but all works,
or nice and tidy and more expensive .
Also on retrofit you do not rip half the ,wall to fit nicely copper with clips and insulated etc as cement or other staff will make corrosion to copper and will be leaking .
So minimal destruction and make it work , or full refurb x3 price and all nice under the floor and plasterboard -water has no spine so matter 🙂
I would do every joint in soldered copper and brasso the copper after .. and add extra support for pipe work in between joists ...I would obviously make a accessible hatch for any mechanical fittings buried in a wall ... powerflush the chrome radiator before adding it onto the heating circuit... as per m.i. ... re do the dodge brickwork if ... only every customer pays for it
Proper plumbers use copper for inaccessible pipes. They also don't use 'solder ring' fittings.
!!! I used Yorkshire fittings on all work for years. Nothing wrong with them for professionals except they cost more than end feed. 🙂
I generally only use end feed now, but still use Yorkshire on 15mm
Reactions: Burger
Disagree most of the old timers use it and is spec on some commercial jobs
Thanks for calling me an old timer. 😉
You are right about solder ring fittings being the norm in the past. Not sure why that was, but rarely see end feed on work done 50 years ago and I was taught to use Yorkshire fittings.
End feed was thought of by many as inferior then.
I suppose you could think of Yorkshire fittings as the faster method of soldering
😀 end feed wasnt around back then as much well that’s what I was told
Yes, I think that is right.
There was the heavy brass end feed fittings about. I do know homes built end of war - 1946, had end feed copper work.
I didn’t do it though!!
That old chestnut 😱😱😀
That's strange because the same website recommends burying copper in lime chippings to act as a preservative.
There must be some reaction when the lime is mixed that makes it corrosive because natural lime isn't corrosive to copper at all, in fact copper artefacts have been found perfectly preserved in lime and they have been buried for hundreds of years.
I fully agree that copper should always be sleaved with felt at a minimum, but I've always done it on the basis it gives the copper an expansion gap and prolongs the life of the copper by reducing abrasion.
I always understood that copper pipe must be sleeved in concrete because it then is allowed to expand and contract and not try to pull itself apart which was just painting it with gloss paint was a none starter
Only reason I mentioned 1946 is it is the oldest date genuinely I know for certain that end feed soldered copper joints were used in houses I worked on.
Just something that puts a time line for me that copper and end feed was used.
I am a bit boring like that. 🙂
