E
everlastuk
hi guys, quick question,
what is the correct distance apart 2 pipes running horizontally should be? is it 30mm? ive just started the city & guilds 6129, just out of curiousity i was wondering when running pipes horizontally would they have to be 30mm apart? its really doing my head in because if that is the correct way then doing a semi passover (crossover) is impossible. Reason im asking this is because someone told me that the plastic clips which the pipes push into on the wall should be close together to make for a much neater job, but wot if you needed to cross one pipe over the other.
Can someone please help me out here.
cheers
cheers
