E
Eddie Charlton
could i have the following clarified please. The use of plume kits is clearly an advantage with condensing boilers and is widly used. when working with my mentor the other day i was wondering if the plume kit itself allows you to deviate from the flue regulations. to explain,- if the flue assembly comes out of an external wall, but is within 300mm of a window, but the plume kit termination it taken away to a distance more than that, does it then comply. (even though the air intake would be withing 300mm. ) i assume it would since the concern of the distances refer to flue products re entering the property?
