Hi all,
I would be interested to know how much you would charge to do the following work in a standard-ish cloakroom.
Strip out room back to walls (solid breeze block walls with plaster skim). Only tiles to be removed are existing basin splash-back and 4 tiles on sill under high-level window.
Break small section of concrete floor around existing copper pipework to run supply pipes for radiator and basin in chrome from under floor. Make good.
Another company to come in and plaster walls.
Paint freshly plastered walls with 3 coats of paint.
Tile floor, 1.5 square metre. Fit new flooring trim.
Fit concealed WC and box in (removable boxing for future access).
Tile front of WC boxing (approximately 0.8sq m).
Fit granite worktop on top of WC boxing and as window sill under high-level window.
Grout tiling.
Fit towel rail, basin and wall-hung WC.
Silicon seal all internal corners.
Separate visit after plastered walls have fully dried (4 weeks later) to tile skirting up-stands (about 3m in length worth) then grout and seal as required.
So overall the project will be done in 3 visits, before plastering, after plastering and once plastering has dried.
It's been a while since I've checked my prices with anyone else. My price for labour only is £1,200 + VAT.
Would be keen to know what you guys/gals would charge and whether (excluding VAT if applicable).
Thanks for everyone's time taken to read/reply!!
Grout tiling.
