A
Aquarius
I can’t see an override on that. I know you said wiring isnt the best, but if you can safely isolate, it’s literally taking a wire and joining up 2 connections, then re-instate power.
Yeah, batteries should be fine, but not a fonk out of it. I read on another forum that the Salus are a bit unreliable, so I assumed it had reached the end of its life.There in the correct way ? The batteries ? As the display should read something
OK, I might take a look at that then and see just how bad my wiring is... Thanks for taking the time, I appreciate itI can’t see an override on that. I know you said wiring isnt the best, but if you can safely isolate, it’s literally taking a wire and joining up 2 connections, then re-instate power.
Isn’t it Com and No?
