Sealing gas pipe sleeve
View the thread, titled "Sealing gas pipe sleeve" which is posted in Gas Engineers Forum on UK Plumbers Forums.
Matt0029
Is this the stuff to use to seal a gas pipe as it goes through a sleeve internally. I went back to one I had sealed with this a few years prior and it had turned green
Also is there any truth in not using plastic talon clips for gas pipes externally sure I read somewhere they said not to because can go brittle?
Have to use uv rated which talon are but I like to use brass clips
And regarding the fjs I’m guessing the oils leached out due to the warm weather
Yes, FJC is pretty expensive though for some putty!
Standard talons are UV stable, not sure about the new coloured ones though
Reply to the thread, titled "Sealing gas pipe sleeve" which is posted in Gas Engineers Forum on Plumbers Forums.
Matt0029,
Scott_D,
