Tell us a bit more about the location of the thermostat, type of boiler, the location of the radiators and the temperature of the radiators when they are one. Picture of the marsupials*, please, and where are they located?
*Not actually needed to answer the question, I'm just curious.
Do buy a thermometer, they are not expensive. I've never relied on a thermostat to tell me accurately what the temperature is!
Ok I will, thanks cool 😊 xx
[automerge]1601543794[/automerge]
To elaborate I found the switching sensitivity to be particularly poor on this unit, even when trying to compensate for it's lack of accuracy it could overshoot by as much as a couple of degrees no matter where it's location. Drove me bloody nuts tbh.
[automerge]1601403838[/automerge]
That isn't a bad idea just to tell you what the actual room temp is and to give you another reference, you're going to get it overshooting because of thermal interia but anymore than one degree isn't acceptible. Your landlord isn't going to change it so set your thermostat to 20 degrees and with your new thermostat see where that leaves your actual room temp.
Ok thanks, I'll look to get one. Thanks a lot 😊 xx
[automerge]1601545819[/automerge]
😊 The thermostat is located at bottom of hall stairs, directly across from draughty front door and there is also a radiator in this space that can't be turned off (as one with no thermostat).
The boiler is Worcester greenstar 30i ERP condensing combi boiler.
Rad temp in living room and kitchen - 5
Rad in 1st bedroom - 5, 2nd bedroom - off and bathroom - 3.5.
The marsupials are sugar gliders 😊 They're really great little guys. Their cage is in the living room on the opposite side of the room from the living door and the thermostat sits directly outside this door. I got a few pictures last night.
"Mum, what are you pointing that thing at me for?"
both of them
Likes a bit of footie! 🤷♀️
