speed fit on secondary return
View the thread, titled "speed fit on secondary return" which is posted in UK Plumbers Forums on UK Plumbers Forums.
Technically plasticiser will leach out of system where water is always changing ,hence more brittle (less spring back to keep things sealed)
Sealed circuit (ie-Boiler) , plasticiser cannot escape gets re-circulated
( PURE Theory no experiece with plastic plumbing--)
Loss of plasticiser and enbrittlement == fact
Trade offs a) How hot
b) How much water thru system
c) How many years of life
d) How many hours a day pump runs
e) Price of install
Life whole system needs to last -vs- water thru system for effect to happen
Copper rules !
Think your theory is wrong, seen plastic that has been used for dhw that is 25 years old and is still ok, not brittle at all
may not have seen effects of plasticiser in pipes ,but seen it leach out of cables and damage painted surfaces -within a year-
Insulation on cable is PVC and should not be painted with gloss and is not the same material as plastic pipe 🙂
Has water running through it every time tap is turned....you been on the pop ? 🙂
The total no. of litres flow at final outlet ,must be nothing compared with continuous replenish hot with hot that happens within pumped secondary return , that stays hot so boosts leaching effect
( any YES Cider )
personally if the manufacturers say dont use it, I wouldnt, as come the day it fails, you are in the pooh as the installer who has to defend your actions.
( any YES Cider )
If it leeched into water it would be banned
the manufacturers don"t say not to use it they say don"t use it on a continuously circulating return maintained at a constant high temperature, I f you're gonna quote the manufacturer at least take the time to read it and get it right!
Insurers will be more happy with leakage from sealed domestic CH system, as its un-likely to flood downstairs.
Un-like 3 bar (mains-fed) hot water , plenty of potential damage .
A good reason for G3 ticket , and a service once in a while !
Personally, I'd say mike Jackson got it spot on. It's not been approved for the relevant specification because its not worth the bothering financially.
Doubt it makes any odds, I'd be surprised if it wasn't tested for 24/7 use. Plenty of applications where heating could be on continuously and for them to release a product that couldn't withstand 'worse case scenario' would be utterly stupid.
My point is ,compare years to failure if constant
with how many more you will get if its not constant . ( Warranty period ? )
Insurers don't like paying for gamblers !
( Have not read instructions as I don't fit )
I"ll choose to ignore it as I dont do nursing homes
I don't do nursings homes but I have clients that are from the Middle East. Usually seven+ bedrooms and bathrooms with servants quarters. They all come and go at different times throughout the year and the set up suits their lifestyle/needs.
Would you plumb the secondary return in plastic?
the manufacturers say no to a return that"s on 24 hours a day why would you install a system that runs through the night, it should also be on a stat to stop the pump running needlessly, then again you would know that being an experienced plumber
And you're point being?
Can you use flexi's on systems that have a secondary return ??:lol:
Im sure they would be less able to cope with hot water passing close by 24 hrs a day ! !
Ok , this may not be exact failure mechanism
( A bit of O2 oxidation , a pinch of Chlorine/Florine ,and some plain old heat-creep )
( external paint / vehicle fumes etc )
Most of the problem is it may have a long 8hr shift
-Hot all day long For Chemicals
........................Heat softening to make a difference
Reply to the thread, titled "speed fit on secondary return" which is posted in UK Plumbers Forums on Plumbers Forums.
sheff paul,
Dan,
