Tap leaks at base of goose neck - repair or buy new one ?
View the thread, titled "Tap leaks at base of goose neck - repair or buy new one ?" which is posted in Air Sourced Heat Pumps Advice Forum on UK Plumbers Forums.
hi,
sad to say my kitchen sink tap is leaking at the base of the goose neck (spout can swivel left or right).............anyone here DIY fix before ?
i saw Youtube videos and seem simple...........just change the rubber O-rings..............but how do i make sure the O-rings are of the same size ?
my current tap is Italian-made...............and over 10 years already.............perhaps should just buy a new tap ?
The O rings wear where they rub, but they only rub on the outside diameter, so it is relatively easy to check the unworn size, even if it involves eyeballing them due to lack of any more sophisticated method. If the new o ring is a slightly smaller diameter that is not a problem as it will stretch.
My opinion is that one should never throw away anything that can be repaired, but there obviously comes a point at which repair is not going to make it good as new, for example if the chrome plating is failing or there is significant wear in the swivel spout. This is very unlikely to occur in 10 years, but it depends on a lot of factors.
many thanks for your reply..................the tap handle is also quite loose (no problems shutting the water on/off)..............by the way, as i'm not a handyman kind of person........... i've a few questions............
1) there's a lever under the sink to shut off the water but the lever is very very stiff.........should i turn it left or right to shut off the water...........?☹️
2) should i buy a new tap, would a tap handle be more durable (less likely to leak) if it turns left/right ? ..............or a handle that flip up/down ?🥺
3) if i fixed the leak at the base of the goose neck with new O-rings, wouldn't the leak move up to the spout at the end of the goose neck ?😱................is the ceramic cartridge leaking in the 1st place and causing the base of the goose neck to leak ?🙄
sorry for all the tedious questions.............😳
Probably, like me, it just has a screw loose.
Normally a lever closes clockwise. If very stiff it may be wiser to isolate elsewhere. You don't need to isolate just to remove the spout as that only gets water when the tap handles are turned 'on'.
A good quality rubber washered tap can have a longer life than any levered device. Quarter turn levered taps (i.e. ceramic disc mechanisms instead of washers) work brilliantly when they work and can be maintained reasonably easily but parts are less generic and more expensive than rubber tap washers which are always available nearly everywhere. They aren't more expensive than rubber washered taps (I've just put new taps (one hot, one cold) in my kitchen with rubber washered mechanisms... £80 the pair). Probably easier to maintain ceramic discs, if a bit more expensive as you generally just take the tap mechanism out and ask a plumbers' merchant for a suitable replacement. If you are going for quarter turn levers, with separate hot and cold levers, then the orientation is unlikely to make a difference to longevity, and you can normally get unbranded spares that will generally fit, unless you're unlucky.
What I would warn you, though, is that if you go for a single lever mixer where one lever controls both flow and temperature, I'd recommend something of quality like German Grohe (at Grohe prices!). When the lever cartridge eventually fails, you are stuck with that manufacturer's spare which may come at a certain cost. If you go for something cheap, you may probably as well regard the tap as disposable (though it's always worth checking - be sure to remember what brand it is in case you need spares!).
Good question indeed. Assuming your leak is just a drip, why not take the goose neck off, dry what water you can see in the tap body and see if it refills over the course of an hour or so?
Yes, shame on you for asking plumbing questions on a plumbing forum. 🙂
Although I've said you can work on the spout without isolating, do make sure you know where you can isolate, just in case the unexpected happens and there's a fault in the casting and tap explodes. Never happened before but...
many many thanks for all the info and answers indeed...............🤩
most likely, i'll have to get a new tap.............i've just read that those ball faucets (like the one i got now - lever goes up/down) are more prone to leaking due to additional parts compared to those using ceramic cartridges (lever goes left/right) ?🥺
are those ball faucets (lever goes up/down) more prone to leaking due to additional parts compared to those using ceramic cartridges (lever goes left/right) ?😬
what about repairing a ball faucet ?.............cost more money too ?😫
Ball faucets go up and down AND turn. The spare part for a ball MIGHT cost more but will depend on the manufacturer. You need to find out what the one for YOUR tap will cost if you want to know the answer.
As I say, if cost is the main factor, use a rubber washered tap. 🙂 Because rubber washers cost around 25p. All my taps at home have rubber washers.
Reply to the thread, titled "Tap leaks at base of goose neck - repair or buy new one ?" which is posted in Air Sourced Heat Pumps Advice Forum on Plumbers Forums.
WorsTalentScout,
Ric2013,
