Vaillant Controls VRC470F
View the thread, titled "Vaillant Controls VRC470F" which is posted in Central Heating Forum on UK Plumbers Forums.
I have a Vaillant Ecotec plus 630 and a VRC 470F Controller. The controller has a radio receiver in the boiler facia.
Now I have a Sensohome controller to install with internet gateway.
The radio receiver for this must be wall mounted and ebus connected.
The question is, how to I remove or disable the original radio receiver? It looks like it is connected to the PCB via the LCD display. I don't really want a blank hole in the facia.
There is a loop connecting the RT24V terminals on the pcb.
Any advice gratefully received.
Usually need a blanking plate, think they normally pop out. Any photo?
Yes, here is a photo. They can pop out from the front? Thank you for the reply.
Yes, that would just pop out, it will reveal about 5 metal pins. I think they work without, but unsure if it would interfere with the new one. If you can’t get a blanking plate a cheap time clock 150 would work
Many thanks. I had a quick google and found the blanking plate. It's now on order (£11). So I just prise it out from the front then? I'll wait until I have the blank though. Thanks again Chris.
Yep, make sure it’s the right one though. I’m sure I tried one of the older ones and didn’t fit. Should have mentioned earlier, apologies
Reply to the thread, titled "Vaillant Controls VRC470F" which is posted in Central Heating Forum on Plumbers Forums.
rgregson23,
Deleted member 120897,
