View the thread, titled "Verify this installation" which is posted in UK Plumbers Forums on UK Plumbers Forums.
what is the relevance of the distance between tees? If you're pulling from one and putting it back in the other, what does the distance between them have to do with it?
It's all to do with the pressure difference between the flow and return ports. This needs to be as small as possible. If it's too big the water may prefer to travel straight past the port, depriving the rads of any flow..
The distance from ports to any bend (or Tee in a parallel system) in the primary circuit is to reduce turbulence in the flow.
Reply to the thread, titled "Verify this installation" which is posted in UK Plumbers Forums on Plumbers Forums.
Thread starter
Joined
DIY or Homeowner
Thread Information
Title
Prefix
N/A
Forum
UK Plumbers Forums
Start date
Last reply date
Thread Tags
Tags Tags
installation
squishio,
doitmyself,
