where to buy iron fittings for gas???
View the thread, titled "where to buy iron fittings for gas???" which is posted in Gas Engineers Forum on UK Plumbers Forums.
Then presumably tap a thread into the hole and install a nipple/purge point?
No. Just offer a pipe up. Get as best seal as possible with a rag or damp towel. And blow it out
Tapping the hole will create heat and there is still gas in the area your working in. Blowing it out ASAP is much safer
Bit confused here ,
right you drill a hole out,put a rag to it and blast through with air to get a compressor ,
then i presume tap a thread in after purging to seal the hole you have drilled???
Bit confused here ,
No. Usually have a 1/2" socket welded on. It provides a purge point for future use and a point to carry out tests
We buy £1000's worth of malleable iron pipework and fittings,Mapress,Xpress,welded fittings every commercial pipe fitting going only place to use is BSS Branches in All major towns, stock everything you could ever need or delivered next day at latest. service and price best you will get if you buy decentamounts, tho cant expect any merchant to jump over backwards for a small sale like a elbow or union can you.
Reply to the thread, titled "where to buy iron fittings for gas???" which is posted in Gas Engineers Forum on Plumbers Forums.
mutley racers,
DavePIPE,
