where to buy iron fittings for gas???
View the thread, titled "where to buy iron fittings for gas???" which is posted in Gas Engineers Forum on UK Plumbers Forums.
Bit confused here ,
right you drill a hole out,put a rag to it and blast through with air to get a compressor ,
then i presume tap a thread in after purging to seal the hole you have drilled???
No. Usually have a 1/2" socket welded on. It provides a purge point for future use and a point to carry out tests
We buy £1000's worth of malleable iron pipework and fittings,Mapress,Xpress,welded fittings every commercial pipe fitting going only place to use is BSS Branches in All major towns, stock everything you could ever need or delivered next day at latest. service and price best you will get if you buy decentamounts, tho cant expect any merchant to jump over backwards for a small sale like a elbow or union can you.
Reply to the thread, titled "where to buy iron fittings for gas???" which is posted in Gas Engineers Forum on Plumbers Forums.
mutley racers,
DavePIPE,
