J
jetblack81
Hi all, please can someone give me some guidance on what I need please. I have an oil fed boiler with a pump fed ch system and gravity fed hw system which I currently can only operate together at the same time. It has 3 pipes coming to/ from it. Someone has previously installed a 2 port valve on one of these pipes but not wired it in. It also has a stat on the cylinder which is wired in but does not appear to work. It is also fitted with a potterton ep2002 programmer.
I would like to be able to control the heating and hot water seperately but also be able to set alternative times for them to come on and off. Do I just need to have the valve wired in and replace the programmer? I had in mind a Honeywell st9400c, would this do the job I want it to do? Any help would be much appreciated.
