jtsplumbing
Subscribed
Nov 21, 2010
5,728
1,784
113
76
Tavistock. Devon
Heating Engineer (Has GSR)
Any one having problems getting hold of the new Baxi Blue range ? Would like to use more Baxi boilers but they have a very limited range in LPG, Now I have the chance to fit a Blue heat only boiler told it may take up to 2 weeks to get one, unless I am prepared to pay £40 carriage charge, Tried 3 main outlets in Plymouth, WHAT IS GOING ON WITH BAXI ???????????????? :annoyed:
the conversion kit from NG to LPGfor a intergas is under £15 and all their range are suitable thinking about it its probably the most expensive washer around
Think I finished up with 3 the same , they kept sending the wrong one, fortunately didn't have to pay for them, but as you say £15 for a brass washer,
Baxi are shocking for for LPG if you want a combi you have the choice of a duotec 28! When a lot of my work is LPG it's no good for me.
I do like the boilers though.
So do I, like you and due to my location I get lot's of inquires for LPG, and would like to use more Baxi's, Even local area rep is disappointed as he also loses lots of sales, cant understand why they only do limited LPG boilers if there is a demand for them.
I'm fitting 10
Eco blues on a project and basically made to order from what I was told. I now get my merchants to keep a 24 and a 28 ins stock for me. With the stand off kit there an easy install
I'm fitting 10
So they are doing LPG Baxi Blue boilers for you ?? if that's the case I will bring it up with local Sales manager
Even if they did a conversion kit for the 24 and 33kw I would be happy.
I had to fit a 28kw on a system with 4 rads and only a shower room a 24kw would of been more than enough.
2K
Boiler Advice Forum
Deleted member 126459
