Just a point I'd like to make. Residents in a Care Home are there for care. Few of them would be capable of or permitted to shower alone. Each day a team of carers will work through the morning, helping residents to wash and dress. I doubt a home this size would ever have even 4 showers running simultaneously, with affordable staffing levels.
wether there would be 4 or 23 showers running at the same time the points is the system would have to capable of running all the systems the laundry the kitchen. in a care home with 23 rooms the laundry will probably be running all day.
Correct gasmk1. We will have a dedicated laundry room with a commercial dryer and washing machine likely to be used all day.
Gpbeck - whilst this will be a "care home" - I am hoping to make it kind of like a rehab unit, so step down beds. It'll mean residents will be commissioned to stay for a maximum of 6-8 weeks only. But this will mean a lot of them will be able-bodied during their stay with us.
I'm guessing 40-50% of the rooms may use the showers at any one time, with kitchen and laundry room needing heating at any one time.
Run a boiler at 43 degrees. The heat loss through pipework alone from boiler to thurthest draw off will be massive. Indeed time for a pen pusher to design system layout etc.
45kw combi sgould do the trick.
I don't know about boilers but with my limited understanding, it will need to be the pipe work and emitter surfaces that are maximum 43degrees. I'm guessing the boiler will deliver a higher temperature.
I can't imagine 45kw combi being able to manage this size of job. But as advised by others, I'll let the experts figure that one out
he was joking 😀
  • Informative
Reactions: jtsplumbing
And there was me getting ready to buy my 45 kW boiler in preparation
If I were you, I wouldn't be buying or supplying ANYTHING for the heating - get a single source installer to design, supply and install, then they will carry all the risk.
That's a good point Murdoch99.
Whale: it's in Nuneaton in Warwickshire. I'd be interested in speaking to you if it's an area you would consider. Is there a way of private messaging me? Alternatively, can you provide a contact number/email.
