Ok Re the fan. A quick rundown on what the plumber (who is supposedly a firebird agent installer) has done.I'm talking about the oil pump not the water pump that's connected to the fan, the boiler fan runs for around 7 seconds to purge the combustion chamber of any explosive gases before allowing ignition. The original boiler circ pump may have been programmed to overrun for awhile when all zone valves close.
I think you should think about getting someone familiar with oil boilers if changing boiler output or whatever, the original burner didn't need changing as its rated down to 26kw with the appropriate nozzle.
New 35 kw boiler installed August 2019 (sized by installer after doing all calculations)
October 2019 first melted condensate trap hose (Steel trap)
May 2020 another melted condensate trap hose
June 2020 another melted pipe
June 2020 new pump installled ( as installer advised us flow and return pipes to small hence condensate trap hose melting)
July 2020 another melted pipe
August 2020 air vent added to flow pipe (installer now advised us air is in the system and this is causing melted pipes.
September 2020 another melted pipe, pump pressure turned down by installer as apparently pressure to high.
October 2020 another melted pipe, pump pressure turn up by installer as apparently to low
March 2021 another melted pipe, pump pressure turned up again as apparently to low.
April 2021 another melted pipe, pump pressure turned up again as to low.
October 2021 installer decided to downsize boiler from to 23 kw as now the boiler is oversized hence melted pipes and pump pressure turned up.
November 2021 boiler downsized to wrong kw output so now sized to 26 kw from 35kw.
April 2022 boiler still not operating correctly.
