Just a quick one...as I'm getting new boiler installed in next few weeks and might take a month or two for the upgrade...
What happens if I have appliances fitted that require more than the current supply? I.e. if I run a 35kw and 40kw combi plus an ago (around 2-3kwh), for combined 77kwh on a 67kwh G4 meter, will it be simple lack of power issue or cause appliance damage?
Wondering whether need to postpone boiler install until work done but would ideally have all sorted before winter kicks in
Get it all fitted but only run one boiler at a time untill the u16 is fitted , low gas pressure will cause the boilers to fail.
Reactions: Mjward
