View the thread, titled "Condensate into rain water pipe...YAY or NAY??" which is posted in Bathroom Advice on UK Plumbers Forums.
mutley racers
Subscribed
The boss and I are installing a boiler tomorrow, and to be honest, the only place to install the condensate is into the rain water pipe. Is this allowed?
I can not see any where that says no.
Also, is there a boss for this type of thing, or do you just cut and seal with silicone?
This is my home work from the governor.
Cheers fellers
I read somewhere couple year ago (cant remember exactly where) that the amount of acidic water now going into sewage or ground is now a concern for contamination . So once this becomes common knowledge we will probably be terminating it into buckets !!!
I did hear couple weeks ago that worcester now are making noises of sleeving the condense pipe through walls , not seen nothing in mi's as yet tho .
i also remember reading something a while ago about condensate in sewers.
the theory says the acidic water from the many 1000's of boilers discharging into sewers will eventually build up and ruin the eco system in there....
i heard this too, but its mainly the utilities companies kicking up fuss because of the increased cost of treating the water.
See section 2.3 and figure 5 to the attached link.
[DLMURL="http://www.centralheating.co.uk/checklists/frozen-condensate-pipes/frozen-condensate-guidance-installer#5"]HHIC » Frozen Condensate Guidance for Installer[/DLMURL]
and just to put a spanner into the works....
unless there is already one there and you are renewing it,
you can no longer install a hopper........
as i was told by a b.c inspector recently, its against building regs?.
I always use to terminate it into a Mcalpine tee if in the kitchen now i try use clamp1gr/wh . But like i have said i have terminated about 4/5 into downpipes this year .
I personnally would first fit the acidic neutraliser if practically possible in the boiler location, then the ph value would be nil then run condense into rainwater pipe, i once had a customer who was concerned that the acidic condense would pollute the local river & harm the fishes, have fun.
Never seen one, anybody else fitted them ?
i seen em at a trade show, its a sock filled with salts that remove the acidity. has the added bonus that it lowers the freezing temp of the discharge. by a degree or 2. but the sock liner has to be changed yearly........(assuming of course that the rads are set up correctly and the boiler does actually kick into condensing mode) lol
last week i saw a condensate cut off flush with wall, trickling down onto flat roof extension, eating away at the flat roof
Reply to the thread, titled "Condensate into rain water pipe...YAY or NAY??" which is posted in Bathroom Advice on Plumbers Forums.
Thread starter
mutley racers
Subscribed
Joined
Location
Hampton court, Surrey
Thread Information
Title
Prefix
N/A
Forum
Bathroom Advice
Start date
Last reply date
Unsolved
Thread Tags
mutley racers,
Rickster123,
