View the thread, titled "Condensate into rain water pipe...YAY or NAY??" which is posted in Bathroom Advice on UK Plumbers Forums.
mutley racers
Subscribed
The boss and I are installing a boiler tomorrow, and to be honest, the only place to install the condensate is into the rain water pipe. Is this allowed?
I can not see any where that says no.
Also, is there a boss for this type of thing, or do you just cut and seal with silicone?
This is my home work from the governor.
Cheers fellers
well you can put the condensate into a rainwater gully, so wouldnt it be the same thing hmmm.. KIRKKKKKKK???? can you answer this one please lol
I have put loads into rain water and never been picked up by gas safe even on inspection on contract works has never been mentioned .
MI's will state tho or cant you do a soakaway?
You can put it in a rainwater pipe if it leads to a combined drainage system, some manufacturers state you need an external air gap though incase the pipe gets blocked.
Lol this is what cracks me up about this game one person says yay another says nay , end of day a bit of acidic water going down a rainwater drain is not end of world better off that than a gas leak !!!
I WOULD BE CAREFUL TAKING IT INTO RAIN WATER DOWN PIPES, especially if you dont know what or where they run to,if it blocks it will back up and probably drown the boiler in a down pour,had it happen a few weeks ago on a greenstar blew the fan on that
Then wouldn't that be the same using a clamp1 gr? Get blockage a boiler can go kaput???
most i have terminated into downpipes you can see where they go to be honest if i go external then inch quarter to nearest drain but at times not possible so have gone into rain water and have inspections on H/a contracts and nothing mentioned about it .
Thanks for the question Mutley Racers! I'd like to know a more official answer myself too.
One thing I have learned is the condensate can eat away at concrete and mortar - I'm wondering what will happen in years to come, if the condensate has been strong enough to erode the mortar mix on drains.
I think I'm correct in saying you can drain it into a limestone soakaway, but must keep it away from the building's foundations, if that's any help. (I've added this because I might be wrong and would like to be corrected, please!)
Yeah you can put it in a limestone soakaway, think it need to be about 500-600mm away from the house. Different manufacturers may vary on distance, just remember the limestone chippings need changing every year.
You can definitely put it into a rainwater pipe if it leads to a combined drainage system, if the area has a seperate drainage system for rainwater and waste water then you can.
i am pretty certain you cant go into down pipes as its against building regs,but would need a copy of the regs to clarify anyway it will freeze in the winter
I think it is 600 mm from boundary or something like that for soakaway,nothing wrong with it freezing in winter imo , call out = £££££'s
hi, dontknow it all. I know it can go into a soak away, but the soak away has to be about 500mm i think from the building. As you said, away from the foundations. Am sure the client does not want a pipe sticking out half a metre along his patio floor
It looks as if that's now been cleared up, but I'd still like to know if it's okay for a rain water drain/pipe as per the original question.
can't answer question as don't know answer, but been to several properties where condensate are just ending on outside, so chemicals dripping down wall, spoke to customer and they weren't too bothered. big brown stain down the wall, lovely.
As has been said. I've seen all different scenario's into rain water or soil. If It's good enough for bg It's good enough for me. Manufacturer's and building reg's are making it almost impossible to comply fully. Think they need to try an install before they write the book on it, As for connection, there are a few ways. To answer can you drill a hole and silicone, that's good enough for bg too
Thanks marley, I know i have seen them done like this before. And that is where i got the idea from. So, i shall give the governor our options tomorrow.
Thanks for all the replies guys. It does seem that everyone has seemed to have done this once. So, i shall have a go too.
The answer to the question is No.
You are not allowed to put into rain water, I am sorry but I cannot remember the reason. British gas had to change there regs because they were told off for doing it.
never silicone a fitting which will have condense water through it as the condense water eats through many silicone sealants.
I never knew that about it eating through silicone. Although if pipe was inserted into rain pipe and siliconed around pipe it would not come into contact. I do stress that this is not the appropriate means of connection and a suitable connection would be better. It's just a cheat really. You will more than likely pick up a hopper from mkm. Or a y piece fitting, then run rain water pipe to point of entry of condensate into building. You could drop 32mm into this.
Reply to the thread, titled "Condensate into rain water pipe...YAY or NAY??" which is posted in Bathroom Advice on Plumbers Forums.
Thread starter
mutley racers
Subscribed
Joined
Location
Hampton court, Surrey
Thread Information
Title
Prefix
N/A
Forum
Bathroom Advice
Start date
Last reply date
Unsolved
Thread Tags
mutley racers,
Rickster123,
