swimorsink
Hi all,
My neighbour is concerned about the location of the flue from my boiler as he believes there is a chance that carbon monoxide may enter through his bedroom window. The boiler was installed circa 1996 and is a wall hung Ideal Classic FF260 with a fan assisted flue. The boiler was inspected last year, the engineer did a visual inspection of the flue but didn't raise any concerns.
Photograph here:
https://www.dropbox.com/s/vrpf1l01zj0ypi1/2015-01-16 16.07.12.jpg
My questions are:
Is it unsafe / is there anything I can do to satisfy my neighbour that it is?
If it is unsafe, do I have any options to remedy the situation other than installing a new boiler? e.g. additional duct work.
I'm not Gas Safe Registered and will be getting a Gas Safe registered engineer to carry out any work!
thanks,
J
That's a funny one as most have to be 300 away from opening but that's generaly when the opening is on the same wall. I know worcester have one where it's 600 away from a window on another wall or at an angle .. Check your manufacturers guidelines in your boiler instalation manual but I say your safe enough
Considering the flue gasses on an old boiler will be at a temperature of around 260°C it's highly unlikely that any products of combustion will drop to that window.
Thanks for the replies. I checked the installation manual and the minimum spacings stipulated by the manufacturer are:
Table 3 - Balanced flue terminal position
[TABLE="width: 500"]
[TR]
[TD]Terminal Position[/TD]
[TD]Minimum Spacing[/TD]
[/TR]
[TR]
[TD]1. Directly below or alongside an opening
window, air vent or other ventilation opening[/TD]
[TD]300 mm. (12")[/TD]
[/TR]
[TR]
[TD]2. Below guttering, drain pipes or soil
pipes[/TD]
[TD]25 mm. (1")[/TD]
[/TR]
[TR]
[TD]3. Below eaves[/TD]
[/TR]
[TR]
[TD]4. Below balconies or a car port roof[/TD]
[/TR]
[TR]
[TD]5. From vertical drain pipes or soil pipes[/TD]
[/TR]
[TR]
[TD]6. From internal or external corners[/TD]
[/TR]
[TR]
[TD]7. Above adjacent ground, roof or balcony level[/TD]
[/TR]
[TR]
[TD]8. From a surface facing the terminal[/TD]
[TD]600 mm. (24")[/TD]
[/TR]
[TR]
[TD]9. From a terminal facing a terminal[/TD]
[TD]1200 mm. (48")[/TD]
[/TR]
[TR]
[TD]10. From an opening in a car port
(e.g. door or window) into dwelling[/TD]
[TD]1200 mm (48")[/TD]
[/TR]
[TR]
[TD]11. Vertically from a terminal on the same wall[/TD]
[TD]1500 mm (60")[/TD]
[/TR]
[TR]
[TD]12. Horizontally from a terminal on the wall[/TD]
[TD]300 mm (12")[/TD]
[/TR]
[/TABLE]
As I read it, my issue isn't specifically called out in the table - and I'm not qualified to 'interpret' how it does translate in to my specific scenario.
I spoke to my neighbour this morning and he has just told me that when he had his boiler serviced in December, the engineer told him that my vent was illegal. So I'm thinking that engineer could have been referring to the fact that the vent effectively hangs over his property (and probably shouldn't) and not necessarily that it's unsafe???
He's having a laugh, if he's flapping about it tell him to fit a CO detector at the window if it *EVER*goes off, you'll talk about it 😉
So it's taken 19 years for your neighbour to raise concerns
Yes - we've been living here for 17 years, but have sold the house getting close to contract exchange. Could be problematic for my sale, so trying to satisfy him that he hasn't got anything to worry about.
Classic FF Heat only boiler MIs no mention of min distance from front of flue, only gives 300 below a opening, nothing about above , as this one is, he could be getting a slight smell depending on weather conditions , What's the 15mm pipe close to flue ?
prv pipe
Would be an issue if a recent install but boiler been in 20 years with no concern.
I would be telling neighbour in polite way to run and jump. If concerned at all tell them to fit carbon monoxide alarm.
E
